rambo3010
hi there just wandering what clutch spring to use? found the n1 weights. need the purple spring, but what one i have a lavender/crem purple.but i believe there is a dark purple also?this is comet102c. also where do i set the secondairy .
YAMMIEGOD3:16
SPRING YA NEED IS COMET PART NUMBER #207758. THIS IS THE BEST SRX SPRING FOR A COMET 102c. IT IS COLOR CODED PURPLE. AFEW YEARS AGO, YAMAHA / COMET SPEC SHEET CALLED OUT A YELLOW SPRING WITH THE N-1 WEIGHTS. EVEN COMET CHANGED TO THIS SPRING AND DISCONTUINED THE YELLOW. NOW TWO THINGS. COMET IS GONE AND THE SRX EXPERTS HERE WILL TELL YA SOMETHING DEFFERENT. RUN YOUR SECONDARY TO START AT 90 TWIST. 3:16 (yammie tony)
