krisdecker
Just completely rebuilt my 91 Exciter then came across another with some issues. Running her til the end of the season then come summer the real work begins.
- Drop my engine in the new chasis
- looking for an M-10 suspension with a 1.25"x136" track
- widen the pogos to 40" (basically Vmax stance)
							How do u widen the pogos, is it very difficult. My brother in law isn't good at riding at all and maybe that would help
			corcan1
nice lookin sleds!
i hope you post with pic's on your summer project as i want to see how you widen the pogo's too!
krisdecker
Widening of the skis is fairly simple but definitely time consuming. particularly making it aesthetically pleasing afterwards.
Im now considering merely converting to plastic skis from an RX1.
Vmax540
I do not know about POGO's(?)  But, Yamaha's TSS suspension can be widened.
http://www.vintagevmax.com/widening.htm
http://www.totallyamaha.net/forums/showthread.php?t=22988
							PZ 1
- Mar 12, 2005
Widening the front tube puts more stress on the original tube than it was designed for. I saw one that was widened that was bent. It would be good to add a full width tube inside.
If you can find a junked TSS V-Max, you could cut the front crossmember from it and use that.
Vmax540
PZ 1 said:Widening the front tube puts more stress on the original tube than it was designed for. I saw one that was widened that was bent. It would be good to add a full width tube inside.
Yes, that is true !
Ie. from my instructions (see above link)
#10 - After welding completely around, take a piece of original frame and slit it lengthwise, pry it open and install it around the extension pipe to double the strength and weld in place.
krisdecker
has anyone actually installed an M-10 suspension in an Exciter/Phazer?
