need help from you clutch guys
tjsands12
West Bend, WI
right now in my 02 viper i am running the heel clicker clutch. red primary spring, 4.3g heel, 3.3 in tip, stock secondary spring at 70%. i think the belt is slipping a little bit. would it help to run maybe a green seconday spring and a different helix (50-36, or 51-40). or any other recomendations. i do have the bender 4x4 pipe on
stock helix is in right now...im not sure which one is slippling but my belts are wearing out rather fast..i put a brand new belt on 2 times and lost 1/8-1-4 of clearance on the belt in the secondary.
Not a good idea to use a red secondary spring with hc weights. I would go to a green at least 70 wrap. Also look for a helix close to 48/40.
you have the red spring in your secondary as well. The green secondary spring is a little stiffer which should hold the belt in the secondary a little better.
Helix
I'm not trying to step on Turk's toes here.....he has forgotten more about clutching than I will ever know. I just want to add that you are using a helix with a pretty steep finish angle for those aggressive weights. As Turk said you can probably make it work OK with a green in the secondary but I think it would work better with a shallower helix like a 48/34. If you go to somthing like that you will be able to make the red secondary spring work at 80 or 90 degrees.
Madmatt
