01 srx rear shock setting please help asap
torelloracing
ct
ok i have a 01 srx the rear shock mount toward the front of the sled has a groove you can place the shock up toward the tunnel or down toward the track and anywhere in between any ideas where ill the the best use out of it im riding sowhat bumpy trails but still run the lakes im leaving in 2hrs for vt please help
try the middle! its not that hard to adjust if you dont like it and want it stiffer, drop it down to the lower setting, take it up for softer setting!
The bolt is knurled(sp) so you loosen the nut then turn the bolt head and it will move itself. Dont try to pry on it to make it move. Maxdlx
thanks i set it all the way down toward the groung and feel like i can take the bumps better maybe its me but i tend to hammer this thing likr i have snocross suspension haha even tho its stock but still love it whats a good suspension for the bumps and the lake ?
