red devil
Just found out that I put a bender 53/35 helix on my slp piped viper everything stock weights are the same as factory setup. The sled did underrev when hitting the throttle 8400 rpm and would climb to 8700rpm forgot tomention wrapped secondary to 80# with stock spring. The sled did wake up after 60' or so and would pull like a son of a gun to the top speed which it seemed to add 6 mph. I was thinking of dropping some weight in primary but was wondering since I had the same springs in it for 5,000miles if I went new will I see rpm's jump up to where I want them? Just wondering what everyone else was running at 1500" elevation or maybe try some different spring combo's THANX IN ADVANCE
