Spent the weekend in Price Co. Wi. Temps where in the upper 20s, lower 30s.
My 2004 Viper S Ran great until we hit the lakes.
If I nailed the throttle, the sled would climb to 75 or 80 and kind of bog with a sound as if a plug had fouled. If I eased the throttle, and gradually re applied it, I would see 95-98 on the happy meter.
The next morning when condtions were cool, I could nail the throttle and see 100, once the temps, warmed back up, the situation described above returned.
I can not recall ever seeing this happen in the past, even if the temp was warm the Viper would climb rapidly to whatever spped it was going to top out at.
Additinal information: the carbs and valves were gone through before the season. I run premium gas. The sled now has 6400 miles on it, 6100 going into the weekend, 5000 miles when all of the pre season work was done. Engine is stock.
Any ideas as to what is going on? Reeds? Carbs? Temp?
Thanks 2datrl
Thanks 2datrl
super1c
Super Moderator
Is your DCS kicking in? Could also be the carbs, would be a good place to start. Check the reeds while your their. Still got good comp?
yamahahaha
or ur air box filter was plugd with snow...? happens to revs, then again there revs lol
Air box is clean, DCS is not kicking in, and I should mention that my friend on his 2003 Viper with 3400 miles on the sled was having similar issues, but not as bad as he was walking away from me on the lakes.
2datrl
2datrl
to warm was making it fat and to much octane
I like your answer
Should I run lower octane in warmer temps?
2datrl
Should I run lower octane in warmer temps?2datrl
02ViperMtn
are the rpms getting up to full in both situations?
The viper only calls for 87 octane. In warm temps it is pig rich due to the temps anyways. Were the carb heaters left in the on posistion by chance
unchained
In upper Michigan the air was so thick Saturday you could cut it with a knife and my sled ran like a turd all day.
unchained
I like where your going with this. Most people dont understand the effects of octane..maxdlx said:to warm was making it fat and to much octane
