MountainMax
RE: Timing setup on 1980 SRX440
Hey Guys, I have my engine put together now and im ready to set the timing, I have a TDC guage but what do I do next??I have the stator plate bolts slightly loose so I can turn it, I put it back on the old screw marks that were there before but I want to get her right on the mark. Can anyone talk me through it please.......
I can give you someone that may now how to help you time that sled?? Would that be good....I dont have any info on that bad boy...
MountainMax
I have worked on lots of yamaha sleds before but never had to adjust the timing, i want this one to be as good as i can get it, if it's advanced too much it will detonate and burn up, if it's too retarted i will lose power, it has to be right on to get this little 440 to make over 100HP!!
S
srx_eh
Guest
What happened to the Tripple? Where you just pulling our chain? Stock looks good.
MountainMax
Hehe actually i fitted the triple in there from my mountain max, it's back in there again, I done this for a reason though, Im working on a deal to buy a 1978 SSR440 sno pro, very similar chassis and engine as the SRX440. I want to fit a SRX 835 big bore engine in it for open modified race class, i wanted to see if it was possible, The SSR has a much larger hood area for more room to hide the pipes. it did all fit in the the SRX so next summer im off for a trip to hopefully pick up the SSR, then the fun begins.........
S
srx_eh
Guest
Will be an awesome sled and I'm sure you'll keep us posted.
MountainMax
Well guys, i got the info and set it to 1.4mm BTDC as the manual recomends, will see how it works out for me.
