X xtcwfo New member Joined Sep 22, 2003 Messages 22 Location Albany NH Dec 5, 2004 #1 A friend has a 97 sx700 w/ohlins that weighs 290 lbs.He tried to set up the rear suspension by the book.He needs to put in a stiffer spring.Question is do you need to change both springs or can you change just the rear one. thanks S s fortuna New member Joined Sep 17, 2003 Messages 453 Age 65 Location wisconsin Dec 5, 2004 #2 on mine i just changed the rear / butttt it took the adj, comp, reb to the limit. had to revale for heavyer spring.call pioneer perf You must log in or register to reply here.
