SDI1000Z
Viper Went Under Water For The Night Last Weekend. We Got It Out The Next Day And Had Running In A Couple Hours. Took Every Electrical Connect Apart And Sprayed Wd In Connections And Put Die Electric In All Connects Also. Rode Around The Boat Yard And All Seemed Fine. Took To Friends House Monday To Ride Around His Ten Acres And check Light Started Flashing. It Is Flashing Seven Times Then Repeats Itself. I Do Not Have A Shop Manual And Cant Find Owners Manual. Can Anyone Tell Me What Seven Flashes Means? I Think It Could Be With The Power Valve Motor. Thanks, Dan
super1c
Super Moderator
The codes are in the tech section under misc. 7 flashes are power valves but what exactly i dont know. Someone else will help im sure. But a good start would be a cleaning and adjustment which can be found their also.
