2002 600 sxr needle jet setting
kzyodie
ottawalake mi
I would like to know how many truns out from a seated position should you do for the needle jet settings on this tripple? I've cleaned out the carbs and re-installed them on the sled and hooked up everything and the throttle response is bogging, it idle's great and I can achieve some rpm's but when I mash the gas it boggs and backfires. I took the carb bowels completly apart, the jets out and sprayed the carbs with carb cleaner, then i took my aircompressor and lightly blew in all the jurnals. Any help would be appreciated.
