Oil Pump failure
jwiedmayer
Manchester, MI
When the oil pump fails on the tripples does it go wide open? I ran out of oil on less then two full tanks of gas. Something is up..
usually yes,first tho is all settings in check,cable isn't outa seat is it?
I'll check the cable. But something is up. Because I had all the oil drain out of the tank on the garage floor this fall. Then I replaced all the lines. I need to check the cables. But I think its more then that. J
