"suspension mod"
amatosrx
VIP Life Member
byron center mi
i put a piece of angle gusset to help from breaking apart. also welded the top plated for the bump stop to prevent from popping off when suspension breaks. i then powdercoated it all to keep from rusting.
Hey amatosrx,,, try a scIII in one of those sleds,,, It will be the one you ride most... Shit U not.... rides just as hard in the corners & can make up more in the inbetweens...
i have a standard m 10 i will be putting in soon. and yes the stock yamahas are not the best. i have one set up very good for what i do.
Have you ever run one? You can do much better...than what you do now with what you want to do...,, With the M-10 you will loose some cornering and top speed,, just a bit ,,, but pretty major in the twisties....
