Ok this is what Hauck rec for there pipes this is what I have. 1-145main,2-3 143.8 clip on 3 polit 45 air jet 1. Now if i just put the 150 mains in and set air screw out 1 1/2 like hauck rec. Would it be richer by leaveing the needle on 3.
Will it be ok or should I go with there rec.
700sx(r) Stock Motor w/pipes
Sea Level - 2000 ft @ 10 degrees +
#1
Main Jet- 150-150-150
Pilot Jet- STD
Mixture Screw- 1 1/2 turns out
Air Jet-1.2
Needle clip- PTO side: 3rd position
Center & MAG: 4th position (4th down from top)
#1
Pilot Jet- STD
Air Jet-1.2
Definately start with Hauks recommended jetting. You have to establish a known baseline and only change jetting from the "tested" jetting specs if necessary.
JM.02c
JM.02c
Where do I get 1.2 air jets any where?
