Carb float height setting
sledderbob
De Pere, wi
Hey guys, the spec from the service manual is .44" to .60". On a 600 triple with the TM 31mm carbs is there any advantage to setting the floats more to the high side or low side of the spec. Stock from the factory was .45" Any thoughts or experience, sled is used mostly on the trails.
