livewire_101proof
wondering if anyone knows if the chamber sizes are any diffrent between 600 and 700 SRX heads - if i can use 600 heads on my 700.
also an idea ive had, while im rebuilding. its a 2000 srx 700 and thought of trying some viper cylinders for the porting they have over an srx. and have heard that part of the cooling problems of vipers are due to the onepiece head design so i thought i could use my srx heads, probably could use the o ring seal like srx or maybee just go to a regular gasket like the vipers use. Im thinking it will work but figured someone here will probably know. wonder if there any powervalve diffrences i would run into also? not sure, but since i already have a cracked cylinder, a bolt broke off in a head, and could aquire the viper parts that it would not be a whole lot more expensive for me to do. maybe its too much trouble and would be better off getting the one stock cylinder and head and paying to get a porting job done.
also if this is done the way I am thinking, it would be a little closer to the idea that so many have had about using viper cdi boxes for the timing advance. i already have done away with the 2000 cdi and harness so the plugs would be the same i think. thanks ahead of time for any input or opinions.
