hi guys so this is off topic but i know someone here can help me lol. I have a 1984 honda odyssey and was running great but carb started acting up so i took it apart and cleaned it it was pretty dirty so after i cleaned it i put it back on and now it will run fine for a minute then start bogging and has no power. It will stay running fine but wont hardly move because of the bogging. I cleaned the exhaust and the air filter checked everything and still bogging, also when i adjust the idle screw nothing happens same with the air screw i just don't get it any other suggestions would be greatly appreciated thank you for your time
Waters88
If it was really dirty, it may need a second cleaning after being run for a bit. Make sure your jets are sqeaky clean as well. May have pulled up another piece of junk into it...?
you have a vacuume/air leak some where around the carburator or after the carburator. Base gasket maybe.
staggs65
maybe float set too low
