madzx2
how hard is it to remove the belly panels from an 00 srx? any tips or tricks? i am thinking i need to just drill out the rivets.
valin
It is not hard, just takes some time. It is easiest to take the 3 pieces off separately.
Yes, simply drill out or grind off the rivets.
madzx2
thanks. i figured it would be just drill/ grinding rivets. ive polaris bellys before. it looks like ill have to unbolt the rear trailing arm mount, right? what about the radius rods, do they have to be removed?
