00' MM700 ....unhook sway bar or leave it alone ?
alaskanbowtie
Haines
I have 2000 MM700 and I noticed the previous owner has one side of the sway bar disconnected . Should I rehook this up or leave it un-hooked ? Whats the pros and cons of either way ? One more question , is it worth the extra 300.00 for V-force reeds , when I could notch the stock ones and run spacers ? Will I see much of a difference going with V-force 3s ? I have a single pipe with snow stuff can , air box mod , 1 shim in heads , and now what to do with the reeds ? I'll will probably going with a boost bottle soon also . THX for the help , this site has already answered alot of my concerns . ;)!
For mountain riding take the sway bars completely off & save 5 pounds of front end weight. you must crank up the preload on the front shocks when you do this. Run reed spacers...V-force reeds not worth the $$$$$!
