How the hell do I adj the needels? Do I have to take the carb apart?
Pretty much. You do them through the top plate.
I took the top plate off and I don't under stand how they are taken out I don't wanna mess anything up. Any one have any tips or pics of what needs to be done?
super1c
Super Moderator
They are tricky to get out. I just unscrew the allen head screws and then the needle and block can be removed. Becarefull not to bend or break those parts. Check the tech section under engine, their is pics of a complete carb teardown. I think their were pics of the needles. You can also loosen the screw that holds them to the long rail controled by the throttle, you will just have to resync the carbs. How to for that in the tech section too. Take you carbs out, much easier. CCC
tedgoesfast
i always tape throttle wide open us a allen key loosing bolt and turn holddown flange sidways and remove needle
there needs to be a video of this.Someone make a video of step to step procedures how to take needles out ..it would be very informative to all us guys who haven't done it yet and are afraid of screwing something up first try..
10-4 blue I have a friend that has done it before hope I can get him to do it so I can learn. I Put pipes on and am getting ready for the last ride take the wife with me and go play in the mountains. I have been to to the highest point I can go 36#$ feet and change so now its play time.
