kyle3201
Need to know who makes a good one and how much
Thanks \
Kyle
Thanks \
Kyle
Max Perf and Mtn Perf....
Automed
Yamaha makes one just bolt on all the stuff from a viper trail.
Longer shocks, trailing arms, radius rods, tie rod ends, wide sway bar, connector links, did I miss something?!?
Why do you want to do this? I've been considering doing it also since I don't do a lot of mountain riding but wanted a long track out of the box.
2ooosrx
- Oct 2, 2004
- Gurnee, Illinois
- www.cbperformanceparts.com
We can make you a set for any length you want. Ours are also the LIGHTEST front end kits in the industry. We can take over 15 pounds off the front end of a viper or srx. let me know or drop me a pm
kyle3201
Maybe
One of customers is debating on buying a trail viper and long tracking it or just going with the viper mountain and and putting a wide front end kit on it
i will sell my stock viper rods for 80 shipped,with tie rods, sway bar with links and mounting plates for 45 shipped
this will make you wide. if you need shocks i have those too for 100 shipped.
Automed
Don't forget about the trailing arms they actually are different (castor or camber angle is different) You can't tell by looking at them but if you check out the yamaha suspension specifications it's pretty obvious.
I don't know what kind of handling side effect it would have to widen the front end and keep the same trailing arms????
the arms have more caster, you can go with more caster but not less. less caster causes sled to hunt.
Outlaw
If I remember right, the only difference in the trailing arms is the angle of the shock mount. They will work fine just the same, I know because it works on mine. Caster and camber are the same.
