srx440D crank bearing
arcticsrx500
Norway, Kirkenes
Have found the 4 small bearings 93306-20633, but is there anybody that know where i can find the two big one? Oem number start with 8H0. Is there any bearing that is interchangeable??
You can get bearings from Yamaha. There is available another similar bearing and only difference is that bearing has pin on outer surface not hole like original has. Easy to convert. I just took crank to machine shop for repair and bearings with numbers went there also... need to wait to get those back.
Hi,
Sorry for late reply. PTO bearings that i use are 93306-30625. Easy to convert to fit.
