super1c
Super Moderator
Done tons of research and im thinking i want reverse now.
Question #1 Whats the average price for one??
#2 Doesnt look hard, ive even seen where you can use the base of the original case and just change guts and cover, true or false?
#3 I thought i read a thread that i cant find where you can use the parking break cable for the reverse lever instead of cutting a hole in the hood. I like that idea, any link to that would be great.
Maybe i did find a summer project after all!!!!!!!!!! Thanks guys.
P.S. This would be for the 04 viper, then if i like it the 02. I guess another question would be does it matter what year reverse i get. Are all years the same??
livewire_101proof
i put one on an 02 viper once, was not hard at all, true, you need the guts and the outer case cover, thats it. The inside is the same this may help. http://www.totallyamaha.net/forums/showthread.php?t=51762&highlight=srx+reverse
here is another post with another way also
http://www.totallyamaha.net/forums/showthread.php?t=64023&highlight=srx+reverse+washers
super1c
Super Moderator
thanks a ton, just the info i was looking for. CCC
