Anyone running Reichards dual carb setup on their SRV 540. I plan on installing The Reichard dual set up that uses the flatslide carbs they sold with the kit . Also am going to run a PSI single pipe. Anyone by chance know what is a good safe starting point with the jetting.
YAMMIEGOD3:16
DAVE, I START WITH EXCITER SX JETTING. WATCH WASH AND PLUGS. 3:16 (yammie tony)
What main did you end up with the pipe on your SX. These carbs may already be set up anyways. I haven't even opened them to see what they consist of.
YAMMIEGOD3:16
155 mj. KEEP IN MIND DYNOTECH DID PIPE SHOOTOUT IN 93 ON THE EXCITER SX AND THEY DID DROP DOWN TO 150. 3:16 (yammie tony)
