I have a problem with my mm 700 it dies when i push the throttle, i have cleaned the carbs, checked all the rubber gaskets and cleaned out the gas tank, i,ll post a little video here it will explain more then what i can do in english
http://www.speedyshare.com/files/21682060/20100329003.mp4
and before the videos was taken i had just been on a short drive with it. i have changed the ignition coils and the cabels for them.
Throttle override switch not adjusted properly?
i have removed the T.O.R.S so its not that =/
everytime it sounds wierd, i press the throttle
I can't tell much by the video except for the sound.
It seems to idle fine, but bogs whenever the throttle is opened. There did seem to be a couple times when it reved up a bit . . .
I would guess that either the reeds are bad, your carbs are clogged, the fuel level in the carbs is wrong (floats), or there is a fuel delivery problem.
There could also be an electric issue - stator, wiring, coils, etc.
I would pull the carbs, fuel pump and reeds and inspect them very closely. Then check the state of the engine itself (compression, leakdown, etc.)
After that I would start testing the electric components.
Also make sure you have good gas, new plugs, and the oil pump is not stuck open.
Do you mean to say that . . .daniela said:everytime it sounds wierd, i press the throttle
Everytime you press the throttle, it sounds weird ?
hahaha thats exactly what i mean.... QUIET! i have changed the coils, and the reeds looks good, i´ll take a look at the floats! i have removed the oil pump so i put the oil in the tank, tnx for the tip! i ha
bad floats or at least thats what its been everytime it happened to the blaster or suzuki srx hasnt had that problem yet(just get a crab rebuild kit or float and needle valve at minimum i bet problem goes away)
i have checked the floats today and they look fine, but i ride at 400 meters (1300 ft) and my main jets is (145,145,145) can that be the problem? or would that just do so i lose alot of power, I have not had the time to test it proper so i dont know how the spark plugs looks like (i have hauck pipes)
You need to measure float height and make sure they float.
TJ500
daniela said:i have removed the T.O.R.S so its not that =/
how exactly did you "remove the T.O.R.S" ?? can you please explain exactly what you did.... tj
