I am thinking of installing an Air/Fuel ratio guage on my SRX...Has anyone else done this?
Any suugestions?
Any suugestions?
mopar1rules
i thought of installing one of them on my 600 rev, a few years back. never did, as i found online while searching, that the probe/sensor gets all carboned up and oily, from the 2-stroke application, and then it doesn't read/work right. heard it was more of a 4-stroke only thing.
at any rate, if you decide to use it, please let me know how it works out for you.
In my dyno room I use a Etas Lambda meter($5000.00) it state of the art... I will have a test chassis set up soon for members to drop the engine in. Then we can also set the clutch up....sideshowBob said:I am thinking of installing an Air/Fuel ratio guage on my SRX...Has anyone else done this?
Any suugestions?
We also have land and sea.....I like the dynojet to load the track
any questions kennedypowersports@gmail.com
toydoc
kennedy_power said:In my dyno room I use a Etas Lambda meter($5000.00) it state of the art... I will have a test chassis set up soon for members to drop the engine in. Then we can also set the clutch up....
Are you going to fab a chassis to a dynojet ATV rear wheel dyno, or bolting up to a dynojet snowmobile track dyno?
Sound like your working on some cool stuff.
I use a asphalt track on the Dyno Jet 200IX ATV dyno
That way U can also tune the clutch and engine R and D as well
We also have a land and sea dyno
toydoc
Will a asphalt track have enough contact area on the drive drum without slip issue?
the weight of the sled and You strap it downtoydoc said:Will a asphalt track have enough contact area on the drive drum without slip issue?
one drum is 12" and the other is 16"
http://www.dynojet.com/motorcycle_dyno/atv_dyno_default.aspx
