383stroker
does anyone change the air correction jet in the summer and if so what to? do you change your need height? just getting set up for the asphalt this summer.
thanks
thanks
ryanryan
Where you gonna run it?
383stroker
i run at Grandbend motorplex. mostly test and tune for now. but going to bracket race it a few times. just to see how i do.
YAMMIEGOD3:16
LEAVE CLIP IN STOCK LOCATION, BUT DROP MAINS TO. 133.8/ 132/132. 3:16 (yammie tony0
If you run without the airbox,just open carbs the stock jetting is pretty close.
383stroker
i run the in winter for jets is a 42.5 pilot and 155, 156.3, 157.5. with a completely guted airbox. and not sure where my needle are at. i going to run a 3 air filters. i was talking to a guy that has ran a srx's in grass drags he change the air fuel correction jet on the outlet of the carb in the summer. just wonder if any is doing that.
383stroker
anyone heard of changing that jet for summer drag racing
I always change the air jet's for drag racing or speed runing.I will have to grab my notes.
I have changed out mine as well for the summer months, just have to check em out for ya.
383stroker
great just not sure what to change them to. thanks alot.
I ran .5 air jet's
Pro116 you used .5 air jets with the airbox removed and stock jetting for grass and asphalt
Ran .5 air jets with stock air box for grass and l also ran them airjets with filters on grass.For aspahlt only you can run with no airbox because no dust.I actually run .5 air jets for speed running to in the winter time.
A good ball park number for a two cycle is 13:1:1383stroker said:does anyone change the air correction jet in the summer and if so what to? do you change your need height? just getting set up for the asphalt this summer.
thanks
Different fuel has a dif stoch number...
13:1 is on 93 fuel
run .7 with a 52.5 pilot. if you foul a plug go to a 50 pilot. ONLY BECAUSE ITS BRACKET RACING. air screws at 3 1/2 turns. 135's straight across. br8es in the pto
that will put ur egt at 1275. or close to it. depending on how fresh your motor is. the air at your track is the same as where i race
jsut a thought.... airbox gives you air from the outside. (with a bender cold air kit) no air box gives you air from under the cowl. what do you want ??? hot air or cooler air???
383stroker
by put a putting a smaller air jet in are you riching to leaning out the engine.
That's sweet you got your sled ready for the asphalt
Change out the carbs to 40.5mm at the least
