x2ryder
I Have A 02 Srx 700 Geared 20/40, Porting, 135 Mains, Hauck's New # 6 Kit With His Launching Weights. (i Really Like His Weights. It's Nice To Be Able To Adust Engagement With The Turn Of A Allen Screw. )anyway I Think The Kit Has A Straight 49 Helix In It. Revs To 8100-8200 As Pat Said It Should. Wondering If Anyone Has A Better Helix For Drag Racing? I Was Wondering If A Multiangle Would Work Better? Thanks
Check out the tech page at
http://www.totallyamaha.com/snowmobiles/aaTECH/tuning page.htm
800
We used to run 54-44 and if the traction sucked you have to go down on the first number. Don't know how that would work with Pats weights
**sj**
Life Member
I've got a new 52/42 dalton which i think will work good? se my post on parts and cams available... or P.M. me..
Before you go changing the helix, what is the sled doing that you think you need to change the helix?? explain what you like and dont like about the rpm on a run, therefore you can get a educated response, not someone looking to unload one of thier helix they dont use, it just might and most likely will slow you down! More information is needed to answer a question like yours
