I took my track out to do some work on my suspension and forgot the order in which the rear axle goes together. Let me know if this is correct...
wheel > spacer > washer > rail > washer > tensioner bolt > spacer > wheel > spacer > tensioner bolt > washer > rail > washer > spacer > wheel > nut
I guess the 4 washers should be up against the rail right? A picture would take care of any questions if you have one.
xsivhp
Sounds like you've got it right.
Yes, the washers simply go against the rails.
thanks guys!
