retro fit large gauges into 98sx
REDMATER
tya
ny
Website
mysite.verizon.net
can you guys tell me what i need to do this,want to put hte large gauges into my 98sx which has the small ones, i know i need the dash pod,tach,speedo,but what about the wiring or are there any brackets i may need. ;)!
i mentioned it in another post to you, yes you need the wiring from the gauges to the connector in your bellypan on the left side. you just need the brackets from the large gauges. and also keep the round black thing mounted on the old gauges and plug it into the large ones, (not sure what it is) , you need that. i just did this to mine last spring. and mack sure the tach is from a tripple or it may not work!
I've done it its simple. You can use the hood harness from a large face sled or make your own jumper which I did. The big black thing is the smoothing condensor and you need it on sleds with out electric start. If you need help let me know.
hey redmater, while you are trying to find out the info you need and you happen to come across a set of white faced guages, which i dont think exists, let me know i want them. i think it would look awesome. i dont understand why no one make them.
