I have a 06 Vector & I would like to remove the reverse set-up & the
chain case cover so that I could inspect the gears & bearings. Is there
any short cuts that I could take. If someone has done this already on
their sled could you steer me in the right direction. When I remove these
2 parts is there any thing that I need to replace because of this.
It's all about remembering where everything goes when you put it back together.
Check on the 4 stroke side.
Here's some info on installing a reverse kit on an rx1 which should give you some visuals of what it's going to look like in there.
http://www.totallyamaha.com/snowmobiles/aaTECH/Reverse/RX1install.htm
The cover seal is reusable and the tough part on reassembly will likely be getting the shift fork in the groove correctly.
