fortress
hi! Can someone tell me the error code pattern and what they mean ?? thx!
2ooosrx
- Oct 2, 2004
- Gurnee, Illinois
- www.cbperformanceparts.com
here is a list of all of the patterns for 01. This will have a combination of lights blinking and then that tells you which code it is. here is a link.
http://www.totallyamaha.com/snowmobiles/aaTECH/codes/FaultLocationCodes.htm
fortress
thx! but,, i was searching an error code for the Powervalve but it seems the valves doesnt returns an error code?!?!? In the manual shop, they said if the valves are stuck in the closed position , the warning light should flash!!? I dont find the error code in the table
viper_chick
I'm not sure if is the same, but for the viper's 7 quick flashes is the error code for the power valves.
fortress
well, thx... my light flash but not quickly.. Maybe i have another problem.. I was sure it was the valve.. But the only thing i know its that my valve are not connect to the cable.. I cannot find anything else in trouble humm
