1sickviper02
I just bought a set of these transfer nuts..how hard are they to install on an 02 viper?
Easiest way is to remove the lower control rod assembly from the slide rail and loosen the bolt remove the lower portion from the shaft, unscrew the stock nuts and replace them with the new hand adjust model!
I have only installed mine while the skid was out which made it all the easier.
Be sure to lube the inside of the new nuts.
Pretty simple
Pretty simple
