sledheadjeff
Hi i have a 1998 yamaha srx 700! starts right up second pull everytime but runs like a bag of shit after because it is only running on 2 cylinders! the other one is not getting any gas/oil! there is good compression, all 3 cylinders have 120psi! but the one cylinder closest two the exhaust can is not getting any gas because the plug is Bone dry!! what could this be? and what should i do?
T.S.U.Filmz
Try cleaning the carbs and flushing fule lines
valin
PM sent.
ottawaair
be sure to check the screen under the needle & seat. Also make sure the needle is not stuck to the seat, closing it off.
yep, clean the carbs, the pilot jets are clogged in the one cylinder.
kirk700 srx
If cleaning the carbs does not work check your stator!
valin
All fixed up.
Sideshowrob
I can't believe it starts 2nd pull.
sledheadjeff
valin said:All fixed up.
Appreciate it ryan! i got myself some mothers polish and some engine shampoo. im going to pull the pipes off and clean it up and make it look nice
valin
No problem at all Jeff.
