seanmurphy26
k got the pipe situation all good but now the exhaust is leaking where the peice that connects the cylinder to the pipe. leaking bad and i cant get the bolts possibly any tighter. so is there something i can do to it? gasket or something?
B2SO
- Aug 18, 2003
Gasket
THERE SHOULD BE A GASKET THERE , IF NOT TRY SOME PERMETEX ..
2ooosrx
- Oct 2, 2004
- Gurnee, Illinois
- www.cbperformanceparts.com
there should be an exhaust gasket for every cylinder! go buy some if you havent already. They are very important!
DoktorC
You should be able to use your stock gasket..I used ultra copper to help seal everything as well.
seanmurphy26
ya stock one was messed up...#&$* i really screwed myself there. now i have to take them off and put the gaskets on wow im an idiot
DoktorC
Stock on is steel...next time be easier with the hammer lol...
seanmurphy26
haha i thought that it was junk because it leaked pretty bad with the stock pipes but i went out and put it on the triple pipes seems to work fine...still kicking myself in the head for forgeting the gasket though....i mean wow
