How are you guys runing the wire? seems to rub through when its under the motor, any where else to run it? would it help inside a hose of some sort so it doesnt happen again. Would hate to pull it all out to fix the rub throughs again.
eric.s.t said:How are you guys runing the wire? seems to rub through when its under the motor, any where else to run it? would it help inside a hose of some sort so it doesnt happen again. Would hate to pull it all out to fix the rub throughs again.
I pulled mine and covered it with flexable split convolute found in most automotive applications but any covering including rubber vacuum/coolant hose would do. I would suggest slitting any rubber hose spirally to keep the harness from working it's way out of the covering and route it in the same location.
madzx2
i re-routed mine up and along the steering hoop/airbox area then down along the clutches.
