I want to install the viper torque limiter. What I know is that you have to align the clutches to SRX specs; do the specs for the alignment come with the instructions for the Yamaha factory part? If not were do I get the specs and would I need any shims or something along those lines.
The info on this sight is great my dealer would lock me out if I requested half of the info I have obtained from here.
Thanks guys.
Thanks guys.
the clutch specs are in the Tech Section under ..http://www.totallyamaha.com/snowmobiles/AAATuning Chart/Specs.htm look at sheave offset and center to center...
800
the alignment specs are the same....... if the tensioner won't fit its because the motor is in the wrong place to begin with......
Thanks guys I will let you know how it goes.
Canuck
The spec sheet also came with my Yamaha Torque Limiter.
