JeepJimmy
99 vmax 700 deluxe. stock track. want to add studs. basic trail riding.. what do you recommend...?
I think Woody's Megabites are the best all around stud. 120-144 would be a good amount. Be sure to match the studs to a good set of aggressive carbides to get the most out of the deal.
sleddineinar
I second that about the Megabites...
JeepJimmy
any idea on what length?
If stock track has about 3/4" for lugs,then 1 to 1.075" should be good. I put the 1.075" with my 1" lug track on the SRX,so maybe 1" should be good.You do not want to go beyond 3/8" past the lugs ..otherwise you could bend them eventually.Hope this helps.
JeepJimmy
i think its an orig. 1" track if thats possible? anyway thats what i measure. thank you for the advice. i have never added studs before since my SRX came with them.
JeepJimmy
anyone ever try http://www.snowmobilestud.com/index.jsp
A couple of bucks
bluemonster1 said:If stock track has about 3/4" for lugs,then 1 to 1.075" should be good. I put the 1.075" with my 1" lug track on the SRX,so maybe 1" should be good.You do not want to go beyond 3/8" past the lugs ..otherwise you could bend them eventually.Hope this helps.
Actually for a 3/4" track youre going to want to go with a .875" stud. Remember, the entire length of the stud is not what is used to account for the length. From the tip to the shoulder.
.875 megabites on a .725 Durasport will give you about .400" of penetration. Almost too much.
JeepJimmy
has anyone used these studs from the snowmobilestud.com. ??? im not sure if its an orig track but i measure a 1" lug height. So im unsure what size to go after?
2ooosrx
- Oct 2, 2004
- Gurnee, Illinois
- www.cbperformanceparts.com
We sell Mega bite for 1.15each. let me know how many you need.
We sell S.S. for .95 ea
We sell Gold digger for 1.35 ea
Backer are .40 each
Double backer .80 each
We sell S.S. 1.325 W/Tall Nuts for $1.15
We sell G.D. 1.325 W/Tall Nuts for $1.35
We sell G.D. 1.325 W/Tall Nuts for $1.65
I think the price will save you all some money.
This price is for the TY member
Bruce
Send P.M. if you need studs
All shipping to lower 48 $10.00
To Canada is $20.00
Backer are .40 each
Bruce
To Canada is $20.00
2ooosrx
- Oct 2, 2004
- Gurnee, Illinois
If you have a 1" lug height, you probably want to run the 1.075" studs. This will give you right around 3/8" of penetration. You could go more aggressive and get the 1.175" but this will be more prone to tear outs and stud bending. I would also recommend you use 120 studs in the track using a 3-2-3-2 pattern. We sell the woody's megabite studs for $1.15/stud and the backers for $0.40/backer. These are a great overall stud without going into the high costs of the gold diggers. If you plan on running 120 studs, we can get you the megabites and backers for $185 plus shipping. The studs are in stock and go out the same day if the order is placed in the morning.
If you find out the track is a .920" lug, I would recommend running the 1.075" and nothing higher. Let me know if you have any other questions. Thanks
