hood swap
YooperMike
McMillan, MI
So, I've been thinking about getting a new aftermarket lexan hood for my 00 Mountain Max. In particular, BRTech's hoods. It appears that their 00 SX hoods are designed so you can install whatever type of windshield you want to put on it. However, I really like the one piece style of their 01 SX hoods with the dual bulbs. My questions are, is the hood the same shape along the bottom so it will fit properly, and going to a dual bulb setup, what if anything is different with the electrical? Dreaming of snow.....
dual and single bulb hoods are thee same only thing different is light gauge pod and windshield. I did this swap on my 98 srx.
So, from the back of the light pod connection, it is the same wiring as the single bulb setup? Just want to make sure if I do this, I don't have to get a different wiring harness from an 01 MM/SX and splice it into the existing. And I know the windshield will be different, the 01 SX version is actually built into the hood itself, from what I can tell. I like the 'claim' of saving 20 lbs off the front end too...
