What kind of #'s does a healthy SRX put up for compression #'s.
YAMMIEGOD3:16
125 psi/ 130 psi. 3:16 (yammie tony).
All depends on gauge used,,,, as long as all cylinders are within 5 percent of each other should be good,,,,, I'v seen one gauge read 110 & the next (second gauge) can say 120.....
My 01' has 12,500 kms runs smooth as a top and it reads 125psi across the board.
madzx2
mine runs great with 120 straight across
livewire_101proof
usuallt numbers ranging between guages depend on gueages with diffrent length hoses. shorter hosed ones will read a little higher than longer hosed ones. when most people talk about reccomended numbers, dont worry if it seems a little low if you are using a long hosed guage. i agree with whammy though, as long as all three are close to eachother you will be fine. most srx's go a long time if they have not been overheated bad or anything like that.
