144" hyfax for newer M-10
I did some searching and found a few threads about using hyfax from different sleds on the M-10. It seemed like ski-doo was for the older metric version and the newer ones are polaris. Does this mean any polaris or only the ones with an M-10? I don't think polaris had a 144 M-10. I also read that yamaha hyfax will work?
Any modern profile Polaris slide will work on the newer non metric m-10's.Its something like '01 and newer models.
I think SWEDE is right. I went to a Polaris dealership and got the following slide.
part number# P139G the rest of the sticker reads-POL SS EDG*G*
'01-07, DRAGON RMK '07 +
I extended my M-10 to 144 and put these slides on. Perfect fit other than had to trim a little off the front to get the screw hole to line up. Also had cut about 8 inches off the back also
mid 90's vmax slides will work on the metric m10. Just did it. Nice tight fit
So I looked at the RMK slides I have and the profile may be the same but the screw hole is in the wrong place. I guess it needs to be an 07+ RMK or are all the screw holes in the wrong place?
Most of the Polaris ones I've used were, you should be able to just cut down the front so the screw hole lines up
