viper
BRAAAPPP420
new york
im doing a viper rebuild. i have a ski doo 136" suspension. can you help me by telling me how to mount this bad boy under my ssled? thanks your answers are appreciated.
Need dimensions from Donner sled,,,, Center of drive Axel too front mount,,,, front to back mount,,,,, and top of tunnel too each..... Will get you safe,,, Then also have your original height dimensions from stock skid..... You will have room to play as to your attack of angle you want...... Sled will sit up more,,, but there is twice as much set in...... Much better ride for sure,,, no loose in performance........
I used the brackets from doo skid,,,,, but I'm sure they would work from Hartman,,,,, still may have to modify shaft length to work though........
The doo brackets had an offset built into them for mounting on inside of tunnel... If I were to have mounted on inside of tunnel or used strait drop brackets,,, I would of had to grind a 1/4" to 3/8" off both ends of the rear mounting shaft.... This was for an 09 137" skid sc10IIII, the sc10III I put in the srx has a shorter shaft....
You can go to dootalk to get dimensions,,, also is a good idea to set skids side by side will also help with set back on shaft mounting locations,,,, take your time so you only have to drill once....
well im not sure if ill be able to get the other skid becuase i bouught the suspension from a junkyard so i doubt ill be able to get the sled it came off of
You just need to get the measurements off another sled that is the same chassis style, I cant remember which years were the same for the Doos, I got all the measurements for mine off the donor sled, 05 Renegade X, think they were the same from 03-06?
do you still have the measurement from that sled because they are probably the same.
