SLP Pipes with reverse
Millinocket Rocket
Sebago Lake, Maine
Anyone out there with SLP pipes on a Viper with reverse? I know it can be done, and you need to trim the battery tab on the chaincase- which I've already done. I've dry-fit the pipes in, and it looks like everything will fit, problem is where the can exits the hole in the bellypan. I can get the pipe through the hole, but only without the stock rubber. The pipe is nowheres near centered in the hole and touches the side hitting the bellypan. Anyone got any ideas what to use to close up that gap instead of the stock rubber? Thanks
