A couple of bucks
Has anyone done this and are there any gains. What exactly do you try to get "lined up".
ottawaair
It is more for 4 strokes with valves. You want to place the open side of the electrode facing the intake valve, or toward the transfer ports on a 2 stroke. I don't know about any hp gains but it will make all things equal, as far as where the plug is firing in the cyl., especially on a multiple cyl. engine. you need indexing washers usually to get it right.
A couple of bucks
If I'm sitting on the sled, at what position are the x-fer port at.....6 o'clock, 5 o'clock etc,etc.
with 12 o'clock being the exhaust side, intake would be at 6 o'clock.
actually if the exh. port was at 12 oclock,the transfer/intake would be at 8,10 and also at 2,4 and 6 oclock. indexing plugs on a 2 stroke is pointless.
A couple of bucks
mrviper700 said:indexing plugs on a 2 stroke is pointless.
Roger that. Saw them in the Summitt catalog. Didn't know if they were applicable on a 2 stroke.
kuips
i was going to buy those spark plug indexing washers..... but i'm not sure as if its a problem that you will be changing the height as to where the plug electrode sits above the piston. so, by using the washers i may be losing performance rather than gaining it?
for those that don't know, the purpose of the washers is to align the open part of the spark plug towards the intake port of the cylinder.
spointless on a 2 stroker, as stated above? anyone use 'em?
PZ 1
- Mar 12, 2005
Dynotech (google) may have tried it. The exact location would be different with different engines, it would have to be tested on a dyno to see where is best. The fuel mixture swirls in a combustion chamber and the point is to get the electrode aligned to get the stream to flow between the gap. Any benefit may only come at a lower RPM and only be enough to be practical for racing.
ottawaair
You could make all things equal by indexing, but with multiple transfer ports, the location if the electrode could be just about anywhere. You would be just making them all the same at this point.
bufalobob
tried this one years ago on the dyno w/ stock & mod 2 strokes....0 h.p. gain!!
bob
bob
Illinoisff133
bufalobob said:tried this one years ago on the dyno w/ stock & mod 2 strokes....0 h.p. gain!!
bob
Did it do anything to the torque curve ?
bufalobob
no!!
bob
bob
