Clutch Kit
IMO none.
They were all tested on one sled with the same rider and are way over priced. You can use mostly OEM yamaha clutch parts with an aftermarket helix to make your sled perform much better
I would buy some aftermarket weights that you can add bolts/washers/nuts.
Pounding/griding rivets can be frustrating and you could nick the weight.
That is a wide open question, it's all in what you are wanting to do. Race,Trail, or Mountain ride.
Talk to Bruce at CB Performance.
He may just sell you a helix or something, based on how and where you ride, weight etc.
Cheaper than an entire kit.
2datrl
Run a 3.6 gram rivet in each hole in your stock weights. Parts will be under $10 & rpm,s will be bang on.
