srx to viper hood conversion?
BRAAAPPP420
new york
i was just thinking about this and i want to know if it would work.
the viper and the srx hoods look similar with the gauge pod and there set up..does anyone think if you were to remove the viper gauge pod and put on the srx gauge pod onto viper, would it fit right? has anybody out there ever done this? i dont really like the look of the viper stock windshield and console/gauge pod.
thanks
it doesn't fit, it can be done though with alot of duramix, about 100bucks worth I figured to graft the top of a viper coul onto the bottom of a srx and reshape the lower section for the headlight. not to mention about 20hrs worth of cutting, splicing, sanding and filling before primer
way different. You would be better off spending the 20 hours putting on a black belly pan from 98 SRX and the putting on your srx hood gauge pod ETC and not have to cut this and that
