yamahadanik
what are the best clutch kit for a viper if i want to beat a f7 or be close to a f7. A get set up whit heel clickers or the Heavy Hitter ramp? thanks
First off you better get some triple pipes for that Viper if you even want to start seeing F7's. The stock 118hp with a clutch kit will not cut it when it comes to the pesky Firecat 700. They have about 140hp stock and weigh in at around 475lbs.
yamahadanik
ok but isnt the awserd im looking for
tedgoesfast
get a pin kit from straight line performance to use cat weights a stock rx1 rear helix i will have to check on what springs ive used and what catweights to use gear it down and make sure u get alot of weight transfer for a roll on
staggs65
short drag race or long speed run. i like heavy hitters for speed runs
madzx2
heavy hitters for topend!!
yamahadanik
it for short drag race
madzx2
ive read that heel clickers are good for short distance, im planning on trying them this year myself
