front end
vmax4ken
wallaceburg ontario
after buying my srx last year ....and looking at other pics..my front end seems to look lower then others.. how can i fix this....thanks
You can switch your top shock mounts from side to side and flip them upside down... that will give you about an inch more hieght. That is the quickest and easiest change besides putting on longer shocks or getting shock rod extensions.
do you mean yours seems lower then other srx's or other sleds in general. if you think yours seems lower then other srx's you've seen it's probably time for a shock rebuild and fresh springs
Looks about right for an SRX... but like staggs says, if you think the fronts getting a little 'lax you can rebuild the shocks and replace the springs. Check your shock 'sag' to see if it is relaxing a lot because of soft springs (measure the distance at settled stance and when you pick up the front end till it almost picks the skis)
