Upnorthguy00
I have a 97 XTC 600. I have not made any adjustments to the rear skid other than loading up the springs alittle. Other than that it is set up the way it came from the dealer.
Here is the problem that I am haveing. It seems to have to much ski pressure. When taking off from a gas pump or any concrete surface the carbides really bite and the track just spins. Is there any good way to set this thing up? I am like 260 pounds. Not sure what to do? I just studed it this year also.
Check out the links in the Tech Pages . . .
Another option is to post where you are located, and maybe someone close to you can help you out.
loosen the limiter straps you have to much ski pressure
