found one with only 3400 km,good condition..$2500 obo..Red for my nephew.No pics only.Guy e-mailed me.
super1c
Super Moderator
thanks
there good sleds for the most part. I have heard of crank problems in some of them. dont remember if it was the crank or a bearing.
They run just like a 700 sxr
07 red heads had a weak crank bearing...can,t remember if it was pto or mag. I toasted one in my 97 700mm & lots of em went south here. They were beefed up in 1998.
Turk said:07 red heads had a weak crank bearing...can,t remember if it was pto or mag. I toasted one in my 97 700mm & lots of em went south here. They were beefed up in 1998.
This is true. I believe it's pto side. Or you get some like my 97 where we didnt crack the motor until 7400 miles. Only replaced the outer crank bearings as a caution. They were perfectly fine.
97 had a weak mag side bearing. It had two bearings on the mag side. In 98 they changed it to one large bearing.
