russellrox
I am looking at building my own sled trailer, I just need a plan for it, was just wondering if anyone had any of these kicking around, pm me if you do, it would be greatly appreciated.
abumpa
Don’t have any plans but I built a trailer for my sled a couple of years ago. The reason I built my own is there are not many available the way I wanted it to be.
If you want an inexpensive 2 place I suspect a used commercial one would be cheaper than trying to build your own. Perhaps one that needs some rebuilding would lower the cost and offer the opportunity for customizing.
I wanted a small, light, single place tilt I could tuck in behind a compact car. I started with an axle and springs from an old tent camper. Built my own shackles, frame, deck, and tongue.
Been using it a couple of years now and it works great. Tucks in nice behind a compact car and tows great. I use one of those covers that extend out over the ski tips, but most of the splash from the tires just goes past the sled. For extra slushy roads I did build small removable deflectors to protect the outer edges of the trailer from accumulating slush.
I also installed one of those gas prop rods to help hold the empty deck in the upright position for one-person drive on loading. Works great!
Four 2x4s angle cut at the rear make a great way to center the sled. The 2x4s are spaced far enough apart to keep the skis up and prevent the carbides from touching (and damaging) the deck. I don’t use studs so no deck protection was needed in the rear of the deck.
Below are a few photos, hope this helps.
![DSC00158.jpg](http://i18.photobucket.com/albums/b138/abumpa/DSC00158.jpg)
![DSC00161.jpg](http://i18.photobucket.com/albums/b138/abumpa/DSC00161.jpg)
![DSC00244.jpg](http://i18.photobucket.com/albums/b138/abumpa/DSC00244.jpg)
![DSC00248.jpg](http://i18.photobucket.com/albums/b138/abumpa/DSC00248.jpg)
john7459
Thats a sweet little shop you have in the background!
That's a great looking little trailer! I've seen a few single place aluminum triton's floating around. Actually I think my work has one but I don't see it often....
What is the outside width of SRX ski's? I just built this
![Trailer11005.jpg](http://i170.photobucket.com/albums/u264/jgsxr1/Trailer11005.jpg)
Is that a 4'x8' tilt jobie from Harbor Freight?
